4430 Clutch operating piston orings
Can anyone tell me the part numbers for the inner and outer orings for piston? One on outside piston housing and the other on shaft. It is in the 66k serial number range. I can t tell from diagram. Not sure if I m correct naming everything. Thanks!
Packing(item 1) for serial # 66K is part # R58588 which subs to R65551. Packing(item 13) is part # R65551 unless piston(item 12) has been updated then one uses R65432.
If you are wanting the piston seals for the traction clutch / inner / smaller piston, I come up with R65550 ad R65551. Picture is confusing for better words! I could be wrong, I am not a not a parts man but, been there and done this many times.
