hoosier43fan
Need advice on a hydraulic leak. There are two hoses that fasten between the grill and the radiator. It was dripping so I replaced the hose that was suspect and only made it worse. The hoses join to a piece with two threaded sections coming up through the bottom plate. I just recall that when I took in to dealer last year, in the mechanics comments he noted that John Deere sent them the wrong part, twice, so he just brazed the part. I'm suspicious but I don't know how to remove this assembly to check. There is a horizontal bolt/nut at the base but I'm not going further until I learn more. There is no access to it that I can find from underneath the tractor. Also yes, the O rings were in place when I re-assembled. Sorry I don't have a shop guide to show, but there are only two lines in this space, in front of the oil cooler. Help please!?
