burnsg2003
I recently had to take off my fuel tank because I had a leak. Put the tank back on filled with about five gallons of fuel. Followed the directions in the manual for bleeding the lines but I open the screw on the right side of the filter and pump the little lever and have even turned engine to change the cam lobe and I am not getting any fuel out of the filter. The pump lever does not seem like it pushes very hard.
How long should you have to pump the lever to get fuel spurting out or is the pump for bleeding the system broke and ideas or suggestions very much appreciated.
