4020 24 V gen light resistor
grwrench
hello, mr TIM & others,, what is the resistance for the generator lamp resistor?? 24 volt system, deere wants about $80. can i hook up another gen. lamp bulb in series ??
The resistor is around 50 Ohms. A second bulb in series would work.
I double checked with the Service Manual, 50 Ohms is correct.
This post was edited by wore out on 03/01/2023 at 10:39 am.
Thanks, wore out, i did not find the spec. in the 4020 tech. manual. i have been fixing JD tractors 55 years,, are you a JD tech??
(quoted from post at 14:23:36 03/01/23) Thanks, wore out, i did not find the spec. in the 4020 tech. manual. i have been fixing JD tractors 55 years,, are you a JD tech??
Nope, NOT an official DEERE tech.
Been repairing alternators since the 70's and have a considerable amount of experience wrenching on green stuff, tho, other colors, as well.
