60 CLUTCH AJUSTMENT
Jhn
It is hard to move the shifter out of gears like there's drag on it from the clutch. Can it be adjusted to fix that?
If you're on a slight hill or incline (where the tractor moves even just a little after shifting out of gear) and don't hold the brakes it will also have a drag on the gear shift.
another thing,... when shifting gears release the clutch handle ahead a bit after the clutch pulley has stopped turning., this makes shifting way easier than just pulling back on the handle and trying to shift.
As others have said the pulley brake may need adjustment... which can be a bit finicky at times. I find it much easier to replace the pulley brake pad if it is worn.
Thanks, I just backed off the pulley brake and it seems to be ok now. I was thinking I'd have to back off 3 bolts on clutch but didn't touch it, so simple fix.
