2020 steering wheel rises
I have a 2020 diesel with the closed center hydraulic system and the steering wheel rises as you turn it CCW for a left hand turn. There seems to be a lot of backlash in the system because of that. I checked the linkage for wear but there is no excessive movement there.
Any ideas? It I something that can be fixed with the steering box in place or should it be removed from the tractor?
Thanks,
Mike
Steering shaft that steering wheel is attached to must rise & fall a little when turning steering wheel. This movement of shaft up/down activates 2 valve bodies inside steering housing. Have you removed rear round inspection cover on LH side of clutch housing & checked to be sure that capscrew visible in hole is "very tight"?? Also have you checked bellcrank under center of front axle to be sure bushing/bearings on bellcrank aren't worn out??
