I have noticed the steering is a little sloppy on my 1935 B so I took the steering cover off, cleaned out all the grease real good. I even pulled the steering rod and cone and cup bearings. They all look good. I am seeing side to side movement in the sector gear. I did remove the lock screw retaining the collar below the sector gear. My question is it a eccentric adjustment because it just goes round and round. I did try to pull the sector gear on the splined shaft but it don't budge at all. I tried heat, pb blaster, and a bfh and it was a no go. Any help or advice would be appreciated
This post was edited by nashranch on 03/27/2022 at 05:54 pm.
