LipRipper3006
I have a 39 B that has a hard time going from high range back to low. It will go from low to high no problem but I usually have to let the tractor die and turn the flywheel to get it to finally click back over to low. It's annoying because 1-2 are too slow for what I do with the tractor and reverse is only on the low side. Is there something I should expect to find it when I tear it apart to fix?
The pto is also stuck on and the lever will spin freely so I believe the fork is broken there.
