This message is a reply to an archived post by Tim S on April 16, 2018 at 06:57:30.
The original subject was Re: John Deere 2940 SCV Rebuild.
hello, mr. TIM,, i tried to contact you on your email,, no luck,, so i found this post,, soo,, here goes,, i helped a friend put a head gasket on a 4020,, BUT we are thinking back to an issue we found as we worked.. the rocker arm assembly was REAL dry & worn. the oil for the rockers comes up the right rear corner of the head. i assume from the rear cam bushing, IF that bushing turns that would stop the oil to the rockers,, correct?? if so, can we split the tractor and remove the freeze style plug to get to the bushing?? i know the cam would have to move forward to do this.. your thoughts?? i am little ROBERT, WARRENTON<< VA> [email protected]
