Im working on this tractor for my boss. Everything worked fine this fall while it was on the grain cart and since that time it has pretty much just sat in the shed. The problem started when I was checking lights while doing the spring service. Had a flasher bulb out on the cab. Got pulled off on a different project so didnt get around to changing the bulb until the following day. At which point I lost all 4 flashers. So I started back tracking. Feed battery power directly to the left and right flasher harnesses lights work fine. Feed power directly to the flasher, flasher works fine except no turn signals. Go back the the main light switch and all sorts of weird things start happening. No flashers in the W position. Go to the H position. With dimmer in high I get inside set of front cab lights, no hood lights and no rear lights. With dimmer set in low I get outside front cab lights, hood lights and no rear lights. Go to F on switch. And its the same with no rear lights in any position. There are 3 wires going to the front cab lights, green, blue and yellow. Green goes to one light on each fender. Yellow and blue are tied together and go to the other light on each fender and it appears the blue wire also goes to the rear floor light on each fender. Dont know if this is correct but its for your reference so you know what Im looking at. Been banging my head against the wall on this thing for 8 hours and I need an outside viewpoint. So is this a light switch problem, or is it one of the lighting relays under the dash? Or suggestions?
