JD WA 14 Decals
legalfarmer
New User
I am restoring a John Deere WA 14 and will repaint the tractor. Any suggestions on where I can get a complete set of decals?
if youre not able to get a reproduction set, you might try a graphics shop, sure its not the same, but alot easier than hand-lettering. ive seen that done, but i wouldnt want to try it.
I think Travis Jorde has decals for the WA tractors.
Legalfarmer I am trying to put together a Database
of the WA14 and WA17 serial numbers and owners. I
would like to include your tractor. My email should
be open. Thanks, Roger
Hello JD8020, I saw in a very old post from 2006 that you had a service manual for a WA14-17? I'm rebuilding a Wagner WA9 with the same divider box and was wondering if you could help with some literature?
This post was edited by SaltyAcres1980 on 02/02/2023 at 07:35 pm.
JD8020 might still be lurking around, or using a different handle, but you are tagging on to the last post of record he made, about 8 years ago, a search of his posts reveals.
You likely aren't aware of this but this site has two different views people can use. You would help yourself by starting your own post and fully describe your needs. This site uses two different views. People using Modern view will see your post and the original post you are tagged onto, so they see the "whole" story related to your post. People using the Classic view only see your post as a stand-alone "Re" to the original post, none of the original post since Classic does not bring old posts to the top like Modern does; they stay in the list where they were posted in time, where you post shows as current. People can swap over to Modern to see the original post, but likely many will not bother to do that.
