mypercheron
New User
I have replaced a 1010 john deere clutch plate ,pressure plate , release bearing and resurfaced the flywheel and set the clutch fingers with the jd227 gauge and adjusted
the pedal freepaly and the gears still grind when you try to put it in gear . The clutch we replaced had washers between the pressure plate and the flywheel which we did
not put back in . does anyone know what could be the problem with the new clutch .
