I have a 720 diesel with a pony motor. I
just put an electrical tester on the
output side of the resistor that then
feeds the pony distributor. It's showing
6v, just like the wire going in. I was
thinking the resistor dropped it down to 4
volts? Or does that only take effect when
it's drawing current somehow?
I'm asking that question to ask this
question then-
I've read some posts on here in the past
about converting the pony to 12v. Not for
easier starting but for powering
accessories. John t responded that the
starter would take a quick 12v burst, at
least for a while. Then put a voltage
reducer in line to the distributor to drop
it to 6v, and it SHOULD be ok. (Asside
from changing the generator, fuel gauge,
sender, and light bulbs). I want to give
it a try. I found a 12 to 6 volt voltage
reducer, and put it on the wire that feeds
the distributor. Testing it before i hook
anything up, I see it also shows battery
voltage on both sides. I'm not going to
hook it up to the expensive pony coils
until I'm sure it's right. I know the
coils will take 6v, as I unhooked that
original resistor years ago and the pony
runs great. I'm also sure they WON'T take
12v.
So what is going on?
Thanks
question then-
12v.
Thanks
