Late A fanshaft
Mike(NEOhio)
Location
Newbury, Ohio
Getting the shaft and tube together, late one with the air pump. Is it better to put the front bearing with the shaft first then then the bevel gear or gear first then the front bearing? Got some wheel bearing grease. How much should be packed in the front bearing housing? Half full?
Thought I assembled the back first then did the front, that way the fan doesn't get messed up, or at least try.
