4430 air in coolant
Hi guys. I sent in my radiator to have it cleaned. I put it back in and put new thermostats in it. Is there anyway to purge the air out of the system. I dont want to over heat it because I didnt get the air out. I ran it for a little while but Im in Minnesota so I dont think it got warm enough to open the thermostats and cycle the coolant through the system. The top hose on the radiator was warm but the lower hose was still cold. Will it eventually work the air out of the system? Will the temperature gauge read correctly if there is air in the system. Thanks a bunch for your advice.
With tractor not running you can loosen thermostat housing where its attached to the engine and start filling radiator with coolant till it starts flowing from thermostat housing then tighten thermostat housing.If it has a cab you'll need to purge the air from heater hoses.I do that by removing heater hoses from heater core in cab roof and directing hoses into container.Start tractor and let it idle,when coolant starts flowing from heater hoses reattach to heater core.You will have to refill radiator as those long heater hose hold a lot of coolant.This works for me.
Paul
Ok thanks. I will get after the heater hoses. I already put together the thermostats. I should have done that when I put them in.
Me personally I just run them with the radiator cap off for a little bit. Turn the heat on full blast in the cab to get it circulating in the heater core. Throw some cardboard in front of the radiator if you can't get the temp up
This post was edited by 620 John on 01/16/2023 at 04:55 pm.
(quoted from post at 17:53:51 01/16/23)
X2.
NO need for any more complicated steps or drama, IMHE.
I used to drill two small holes in thermostats on GM cars after I noticed that OEM GM thermostats had a small cut out on the side for venting air. My 69 Camaro will not bleed out the air without the hole unless I get it pretty hot.
If your concerned wait overnight with the coolant cap loose. I think most thermostats for tractors have a small hole in the flat middle section usually with a little metal triangular stopper of sorts that lets air bleed thru. No drilling needed. I knew someone who used to install one thermostat each way on a dual thermostat system so he wouldnt ever put both in the wrong way. A lot of housings are made so the right direction is self explanatory
already mentioned to use thermostats with a "jiggle valve"
or run Mr. Gasket 4367 thermostat (this is the correct P/N for my 4230) and is a great copy of the old Robert Shaw thermostat's that I'm confident were OE for Deere in the 60's and 70's (and possibly 80's)
They are provisioned too with an air bleed.
Flow Kooler (top manufacturer of Water Pump impeller's for high horse power hot rods) I think is the only company selling Robert Shaw thermostats.
https://flowkoolerwaterpumps.com/collections/thermostats
just wanted to post another source for Robert Shaw thermostats (as they don't sell direct to consumer)
https://www.stewartcomponents.com/index.php?route=product/category&path=61
