Who knows what the oil filter bolt screws into on the top of the oil filter body?
Seems to be similar to a square fender not held inside a clip. As we all know when the clip gives out they are a bear to remove. When removing my filter, the exterior nut under the filter cup turned and turned without loosening. I had to bump it with an impact. Now I can't get it back together because whatever I'm trying to screw into is floating around.
Don't think I'm interested in removing oil lines from the top of the filter body and dropping it out...
James
James
