JD 620 gaskets/o-rings/seals
Farmer MM
Ours: 1957 JD 620 gas.
What are best sites to buy all needed gaskets/o-rings/seals for radiator/water pump/steering shaft housing?
Look up the part number of the specific parts you need first. Do not just walk into any dealership, after market parts dealer, or online source without doing your homework.
Check with John Deere first, you will be surprised at the things you can still get for the old tractors.
Check this site, they sell many common parts.
Google search of part number can help find less common parts.
Sign in to jdparts.com and check availability at your local store without even leaving your house.
Thanks for direction. I have about six stores (like Steiner/A&I) that I check. I use JD website for schematics/part/numbers. Didn't know I could check availability at JD, so will do.
The jdparts.com site is AWESOME!!! They automatically converted my old part numbers, making it much easier!
Thanks again!
