John Deere 70 lp inline fuel shut off solenoid/valve
flatheadvff
New User
I have 3 John Deere 70, 2 720, and a 60 that have a 12v fuel shut off solenoid/filter/valve. I'm looking for seal/gasket kits with filter. Used to be readily available, but at 60 something years old, believe it or not parts are getting harder to find, haha. Not only can I not find the parts, but can find no original part numbers or even mention of their existence on the internet. If anyone has information as to a source or even the original John Deere part numbers, I would greatly appreciate if you could give me that info. Also the replacement tank hand valves come with cheap pressed metal handles and smaller stems then fit the original handles. If someone has info on replacement inserts that fit the original handles and replacement original style handles, I'm looking for some of those also. The 70s are my latest acquirements, one is running at this time, two to go. Found on auction,no one was bidding so got them for opening bid.. Kind of funny, like I got good better and best. One is manual steering std pto (good), one is power steering std. pto (better) and one is power steering and live pto (best). Intend to sell one and two, and maybe keep #3 as a free tractor.
The part number for the entire unit is AR26437R, see
JD parts link. I did not find any actual parts available
under that number and the JD parts site does not
recognize it which I assume to mean it is not available
through them. There was some talk in an older YT
posts from 2009 I ran across that talked about a
propane supplier that handled the internal parts you
are talking about. Just do some web searching using
the description you gave in the title of your post.
JD 70 LP parts page
Thank you for the information. I have been searching the web and wording it every way I can think of and coming up with no results. Everything coming up is waayyy off base from my description. So a part number is hopefully going to help get a search on track. uote]
flatheadvff about 5 years ago I purchesed a complete
filter-shutoff assembly from Century Fuel Products for a little over $100.00. Only external difference was no pipe drain plug on bottom of bowl. The bowl was sealed with an o-ring instead of
a flat gasket. It was necessary to reclock the inlet-outlet ports.
The part number was C-2385B. It is labeled as "Fuelock Filter".
71int
