A common issue wanting some fresh advice. Transmission can partially slide out of one gear and effectively be bound up as if it is in two gears at once. Wondering if there is a fix that doesn't involve a complete tear down of the transmission. I know one fork slides freely and the detent is stuck or worn out, I suspect this could be most of the issue. Can the rails and forks be pulled without pulling the clutch? I think the rails slide in from the flywheel side of the tractor, right? I'm thinking if I could replace or free up the detent this might solve the issue without total tear down. Thoughts and comments welcome.
Thank you all!
Thank you all!
