Poppy Johnny
Okay everyone, I recently bought a John Deere 60 at auction it needed some light work but nothing major, a big problem now however is that I found water in both the transmission and the rear PTO, the later wasn't a problem as the PTO housing was cracked (Possibly from freezing or a fool hitting a PTO shaft into it) but luckily a swift inspection showed nothing wrong as while some rusting did happen the oil left kept it from solidifying or spreading and the same being said of the transmission.
That being said I am wondering how the water got into the transmission to begin with? The only entry point I could think of would be the transmission shifter but the sheer volume of water that somehow got into the transmission even if it was sitting for three or so years makes it seem improbable and the only other option, I can think of would be it entering from the PTO housing but there are seals that should have prevented that even if it was cracked.
In any case, like I said none of this water seems to have done major damage but if I don't repair the leaks, it will just come back later so any advice on probable points of water entry would be appreciated.
