My JD 410B Turbo backhoe got coolant in the oil due to a head gasket failure, and spun several rod and two main bearings before we caught it. The crank was salvageable but the spun main bearing bores in the block were badly worn, to the point that my machine shop can't salvage the block. I've been searching for another 4219 block with no luck, except for cores of unknown status.
I've located a complete running engine from a Hydro Ax 221 feller buncher. It has no Engine ID plate, it has a block ID of R90170 and injection pump ID of DB44275002.
I've sent many hours trying to research these numbers to assess whether they could replace my 4219T. I'm pretty sure the Hydro Ax 221 only came with a 4239T but the injector pump seems to indicate this is a 4276T 115 hp, way more than the 65 hp of the 4219T. I don't think the power ratings are horribly incompatible, but I'm most interested in whether this will bolt in and function in my 410B.
- Do the block and injector pump ID's reveal this is a 4239T, or 4276T?
- If these aren't definitive, is there any other external marking I can use to ID the engine?
- Am I on the right track? The only visible external difference I can see from the pics is a much larger oil cooler, as the 4219 had the oil filter inverted and mounted to a small 4 x 4 inch coolant heat ex changer - the replacement engine has a much larger cooler and the filter is mounted horizontally, above and to the rear of the fuel pump.
- The JD parts catalog references short and long noses on these crankshafts. How can I tell the difference externally, and would it matter? The 410B hydraulic pump is directly driven by the front of the crank, but I don't know if anything was similarly driven on the Hydro Ax - the front pulley looks like there was something bolted to it's face similar to the 4219T but I'm not sure this is meaningful, or whether it would make it compatible with the 410B hydro pump.
I welcome any inputs, experience, or guidance - the local JD dealer service dept has been absolutely no help in trying to assess compatibility of any replacement engines. Thanks in advance -
All pics are of the replacement /unknown engine.
This post was edited by sovste22 on 01/06/2023 at 06:37 pm.
