5425 john deere brakes
Dale2
I am working on a 5425 deere cab tractor. The left brake line was rubbing another line and rubbed a hole in it. I have a new line installed but need to know how to get the air out of the system. The brakes work as long as you pump them first but the next time you g to use them you have to pump them up again.
Thanks for all the help
Dale
Bleed JD utility tractor brakes similar to bleeding automotive brakes. Bleeder is item 4 in photo below.
Thank you. The parts guy which was suppose to know everything said they will bleed themselves. We all know better than that.
again thank you
