John Deere 310SG backhoe attachment deminsions
Jaypat88
I found a used rock hammer that has 14" pin holes on center for the bucket attachment. I understand that the JD 310sg has 12" centers. I am curious if the 14" pins would fit? The hammer I am looking at is a OKB 304. The specs for this hammer says it is for a 10k - 16k Carrier rating??? It seems like the 310 hydraulic pump is good enough. I also believe I will need to bore the pin holes to fit. Any help is much appreciated.
I don't think the 2inches will matter
much. It will be taken up by h bracket on
the cylinder. May change how much curl
in or out it will have but you won't have
it on all the time.
