Hello guys Im in desperate need of help from you gurus. So I have
i John Deere 310 3 cylinder. I originally got the machine non
running and basically needed a full engine overhaul. So I took the
engine apart and did an In frame rebuild. Next was the injection
pump. I took it apart cleaned absolutely every little piece. Did a full
rebuild on the pump as well. Everything looked good. Plungers
werent sticking and vent wire is free. Also has new governor ring.
My issue is after putting it all back together the tractor starts and
runs for a few seconds then dies. If i try to start it right after it dies it will just crank and crank and not start. But if I let it sit for a few mins its starts right up but does. I have tried just about anything.
Like checking return like glass ball.I have taken the pump apart 3
times already each time triple checking everything and all is good.
I have bypassed filter housing and run clean diesel from a jug. No
matter what I do it does the same thing. My only other option is the
injectors but I would like a second option before I buy a different
set.
set.
