950 and 1050 injection pump
Scotty
Hello. I'm working on bringing my brother's 1050 back to life after chunking a rod through the side of the block. Couldn't find a 1050 block to start over with but I did find a 950 parts tractor. If l did my homework right should be the same block and I think head just doesn't have a turbo set up. Gonna use the head and injectors off the 1050 blown motor to put on the 950 block that's eventually all going back in the 1050 to bring her back to life. Does anyone know if the injection pumps and injectors are the same on these 2 tractors? Is the only difference in the 2 motors is the turbo?
Thanks
Scotty
Injectors are the same for both models. Injection pumps are different part numbers, probably due to higher fuel delivery setting on the 1050.
Not sure where some of the homework info was sourced from .
