Company Logo (800) 853-2651 Shop Now
47 B Transmission Diagram
Allen Goodman
12-31-2022 08:29:26
Guys,
Tore down my transmission on my 47 B a month ago due to breaking 3 gears while mowing this past Fall. I assumed the mower had a grade 0 shear bolt. Ohhhhh Nooo. Got the gears now, ready to put back together. It's been over a month since I dissembled it and my memory is about as long as the tip of my little finger to the first knuckle (I know what you guys were thinking) since turning 68. My IT manual is not detailed enough and the on line JD parts break down when printed is blurred. Looking for a good clear diagram. Thanks
50supera
01-02-2023 17:18:13
 Re: 47 B Transmission Diagram in reply to Allen Goodman, 12-31-2022 08:29:26
The worst enemy of a JD B tranny is a rotary cutter (bush hog).
J.Wondergem
01-02-2023 10:40:48
Over running clutch will do NO good hitting a rock.
wore out
12-31-2022 10:21:18
Third Party Image
Third Party Image
Dunno if these are clear enough to help?
Allen Goodman
12-31-2022 12:31:16
 Re: 47 B Transmission Diagram in reply to wore out, 12-31-2022 10:21:18
Great! Thanks, How about the shift forks and drive gears?
Mark-Ia
12-31-2022 12:59:41
 Re: 47 B Transmission Diagram in reply to Allen Goodman, 12-31-2022 12:31:16
You can look this up at www.jdparts.com for a free parts book.
Allen Goodman
12-31-2022 13:47:55
 Re: 47 B Transmission Diagram in reply to Mark-Ia, 12-31-2022 12:59:41
If you read my post, you'll note I did that. The on line parts looks to be copies of the book and when you print it out it's so blurry it's difficult to make out.
Mark-Ia
12-31-2022 15:39:43
 Re: 47 B Transmission Diagram in reply to Allen Goodman, 12-31-2022 13:47:55
Hold down the Ctrl button and roll the knob on your mouse to enlarge the picture for viewing.
Pete in MD
12-31-2022 09:31:57
If you don't have an overrunning clutch on your B pto shaft when you mow you should get one.
Leroy
01-01-2023 08:14:45
 Re: 47 B Transmission Diagram in reply to Pete in MD, 12-31-2022 09:31:57
I have used bar mowers on the Deere for years without an over running clutch, Now a rotary might on some be different but on the rotary mower I had did not ever see a need for one.
Allen Goodman
12-31-2022 09:51:23
Had one. Don't work on a sudden stops hitting a rock. Overrunning clutches are only good when you de-clutch.
Pete in MD
12-31-2022 20:27:16
 Re: 47 B Transmission Diagram in reply to Allen Goodman, 12-31-2022 09:51:23
If an overrunning clutch is working properly it's ''good'' with the clutch in or out.
Allen Goodman
01-01-2023 05:37:23
 Re: 47 B Transmission Diagram in reply to Pete in MD, 12-31-2022 20:27:16
Negative, try it.
wore out
12-31-2022 08:52:44
Is your serial number below or above 201,000?
Do you need only the transmission drawing, or the PTO parts drawing, as well?
Latest Ad: Wanted 13x28 power adjust rim for D 17 allis in NE Nebraska [More Ads]
