I'm having a issue w/ my JD H Wico C (similar to some I've read in the archives here). The mag worked fine after I got the tractor(once i put a new cap on it). After the tractor sat indoors for a year, I got motivated to change oil and fix coolant pipe leaks. Got ready to start it and no spark. The points never did look good, so I disconnected the coil & condenser wires and checked for continuity (across the points) w/ my ohm meter, (and there was none). Since I had a new set of points on the shelf (that I bought from the German sounding name catalog guys) I put those in (found out that I had to whittle the corners of the spring side contact holder for free motion ) gaped them, and still no spark. OHMed them out with the meter and no continuity , I polished them with a rouge cloth, dollar bill and business card, i could then get continuity thru them , but only if I lifted the spring side and let them roll off my thumb to snap closed (continuity wasn't repeatable). Still getting no spark, after reading several posts here I'm starting to conclude that I have a bad set of points. I looked @ NAPA (per a archived post here), they don't offer the CS2200 (only 2201 which from the pics don't look like a replacement). Any thoughts on my mag problem and a source for replacement points? Thanks
