value of an engine overhaul
David from Kansas
My son owns a JD 4230 he bought used about 40 years ago to use as a round baler tractor. He did custom baling for many years
with little maintenance required on the tractor, but recently it has gotten really hard to start, loss of power, etc.
Today while riding with him we drove by the 4230 attached to a bale processor and he commented on having overhauled the
tractor and now it will start easily at temps in the teens compared to having to use starting fluid previously to start it
each and every time in the summer. I think this tractor has 20K plus hours on it. He is a JD mechanic and does most of the
mechanical work on his many tractors, combines, swathers, trucks, etc. I remember reading on this site about the difficult
problems with the JD 30 series tractors and recommendations to always replace valves and seats when overhauling these
tractors as low engine compression is what is causing the hard starting in many cases and I believe that was true with my
son's 4230.
I buy several tractors and an overhaul with receipts and done correctly is a plus. In cheaper under $20K tractors unfortunately a $10K + overhaul doesnt add much over a solid runner. You almost have to use it out of them to recover your inputs over a several years.
Son has an advantage in the expense column as he did all the work of overhauling the engine, (except the head work which he had done by a machine shop). He wasn't sure what all was done to the head but was competent that they did everything that was needed. The tractor never did any tillage work after he bought it and will probably now serve for many more years.
