Limbhangers
Tractor currently has worn out 18.4-34's on the rear. It has dual hubs installed currently on the axles.... although just eyeballing they are pretty narrow. The hub is effectively flush with the end of the axle shaft. I have to assume this was likely the most narrow axle width offered on these machines.
What are my options on setting up duals? I am getting NEW rubber all around so this is reason for the question.
We use this tractor to pull a batwing for most of our mowing and I would like duals for the additional stability on side-hills as well as the additional traction. Mud is not really an issue as far as getting the tread tight.
I would also consider scrapping it all and putting on some wide super single style tires as well I just don't have any experience with that kind of setup. None of this is common in my area row crop farming is pretty much scattered at this point.
