Alternator for LA JD
Richard G.
Friend wants to put an alternator on his 42 LA.
What will fit without cutting the sheet metal.
Richard in NW SC
A small single wire alternator should fit in place of the generator on the LA. I got one a few years ago for my 40 from Agri-Service and it is quite small. Diameter was the same size as the delco generator you would find on an M or 40 series tractor and the length was shorter.
I have used several of the dense mini alt. They work great on several small tractors like the La and Cubs where you have limited space. eBay has them for around 75.00. They used to be 50.00
