Tractor is a 4230, sycro-range gear box, 158 loader, with 4 post roll guard station that's been owned by us for 30 years or so.
I'm essentially doing an in-frame on it due to a liner seal failure from having just tap water in the cooling system that turned to rust water. It's last in-frame was 11 years ago and it's only got a few hundred hours on it since then as it's primarly used for discing fire breaks along fence lines/county roads, setting out hay, shredding when needed, and brush control work.
I'm not a tractor/heavy diesel mechanic, but do all my own mechanical work as a hobbyist on my mopar's (except for auto gearbox rebuilds or setting up differential gears) and this project seems pretty straight forward.
My Uncle was using it to do some shredding and it abruptly starting blowing steam out the breather tube which had us thinking it *may* be as simple as a head gasket, even though it turned out to be a liner seal. Immediately after it happened, we drained the oil & coolant, filled it up with fresh oil, and only ran it enough to drive it on and off the trailer and back it in the barn where it sits.
I've already got the head off and at the machine shop and the oil pain dropped. Next up is I'm going to remove the radiator and remove the pistons & liners and pull a main cap to check what size bearings are in there to prepare for ordering a rebuild kit.
I've got a few questions though.
Will I have to remove the diesel injection pump? If so, is timing it a straight forward process?
Once everything is set out on the table and we can clean/inspect all the parts, would there be any reason NOT to just order a full in-frame kit and put new pistons/liners/bearings in it?
The engine serial number plate is gone; how do I go about identifying the block information to make sure when I order parts I get the correct parts?
Is the Reliance Hyper-formance kit the one to get, or standard pistons & liners?
Use the Headgasket with the Reliance kit, or buy John Deere/Felpro headgasket?
