cookieman8772
I have our 46 B put back together. But for the life of me I can't make it run smooth, or increase off idle more than a couple hundred rpm if lucky. It eventually dies out. The carb has been over hauled. Magneto is new and been tested. Head gasket is new. Read about a possible governor issue. But I believe that is working. It visible moves the rod in n out. Plugs new. Wires new and correct.
It runs kinda smooth then will get lumpy and blow black smoke. The intake side of the carb gets moist on the outside. So I took the air filter dust collector off, wondering if it was choked.
Any advice would be greatly appreciated.
Sincerely,
The Starter.
Sincerely,
The Starter.
