Company Logo (800) 853-2651 Shop Now
Moving tires on John Deere 3010
ReTex5
09-22-2022 18:49:37
Howdy y'all, went to move the tires on my new to me 3010 and noticed that some bolts are missing.
I have the 3 cap screws on both sides but don't have the 2 Jack screws.
What exactly do they do?
Can I just move my tires and go back to work?
If not what size are these screws and or what is the Deere number for them?
Thanks in advance.
rockyridgefarm
09-25-2022 04:58:36
 Re: Moving tires on John Deere 3010 in reply to ReTex5, 09-22-2022 18:49:37
One thing not mentioned yet is that someone in the past may have snapped them off when trying to move them. If that is the case, you really should get the broken ones out because they can prevent you from properly tightening the wedges. They could also have been turned out too far and the little keeper could have been pulled off. That would be a better scenario.
I moved the wheels on both my 3010s for what could be the first time in decades. It can get INVOLVED
Third Party Image
Third Party Image
Third Party Image
Tx Jim
09-24-2022 04:23:30
You're welcome.
I had a thought. Bolt part # I posted was designed to move wheel in/out on axle & requires 1 bolt on each wheel. Earlier you mentioned needing 4 bolts which makes me think you need the 2 bolts(item 9) on each side to loosen wedges which are original part # A4882R which subs to R39758
Third Party Image
ReTex5
09-23-2022 20:13:26
I would like to thank all y'all for your help, especially Mr. TX Jim, I found a guy who had a set of bolts in the next town over for $30.
I'll get them tires moved tomorrow and be back in business.
Tx Jim
09-23-2022 08:13:37
If you need to get wedges loose JD recommended hitting exposed end of axle squarely with a large sledge hammer.
ReTex5
09-23-2022 20:10:09
 Re: Moving tires on John Deere 3010 in reply to Tx Jim, 09-23-2022 08:13:37
I love it when the recommendation is to hit it with a large hammer.
I know that's what I do in place of yoga, really helps to get you in your happy place.
Not that I am a violent person mind you, :).
MSD
09-23-2022 07:08:52
One way to move the wheels is to turn the wheel so that the pinion shaft, #12, is on the bottom. Get the wedges loose and the wheel will drop down so that the pinion does not engage, You can slide the wheel in or out without having to get the pinion loosened up. Be careful that the wheel doesn't tip with the wedges loosened or gone.
Third Party Image
Third Party Image
Parts list is from a 730 but should be the same.
ReTex5
09-23-2022 07:57:49
 Re: Moving tires on John Deere 3010 in reply to MSD, 09-23-2022 07:08:52
Might be what I wind up doing, not a lot of these old tractors near me, and $80 is a lot right now.
Tx Jim
09-23-2022 06:54:58
If one chooses not to leave jack screws in place in cast wheel then one jack screw will be enough
Tx Jim
09-23-2022 02:51:54
The pinion shaft aka jack screw is part # A4380R which subs to R83588 @ $76.93 each. You can probably purchase used screw at tractor salvage yard.
You can view 3010 parts catalog @ Link
Third Party Image
This post was edited by Tx Jim on 09/23/2022 at 02:52 am.
ReTex5
09-23-2022 06:20:32
 Re: Moving tires on John Deere 3010 in reply to Tx Jim, 09-23-2022 02:51:54
WOW, that is a crazy expensive bolt, and here's the thing, I need all 4.
Here's hoping I can find them at a salvage yard.
Is it safe to use the tractor without them? Just until I can find some.
tomstractorsandtoys
09-23-2022 06:36:32
 Re: Moving tires on John Deere 3010 in reply to ReTex5, 09-23-2022 06:20:32
The jack bolts are only used to move the wheels. You can buy 2 and use them to move your wheels and then store them somewhere else. Your owners manual will give complete directions on moving the wheels. Tom
ReTex5
09-23-2022 06:43:24
 Re: Moving tires on John Deere 3010 in reply to tomstractorsandtoys, 09-23-2022 06:36:32
OK, well that's a little better.
Today's Featured Article - Pop's Tractor of Gold - by Gary Teate. My father was a simple man but could repair just about anythin mechanical that was ever made. From the time I was a young boy growing up in Jacksonville, Florida, I would spend a considerable amount of time helping my father repair or rebuild equipment and engines, etc. on our 2 1/2 acre "spread". Pop always dreamed of having more acreage out in the country where he could retire and tinker as much as he wanted and often reminisced about his boyhood days on his grandfathers farm in Montecello, ... [Read Article]
Latest Ad: Looking for a skid for a W_power unit----also a green & yellow John Deere antifreeze gallon can. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
