1948 John Deere B umbrella bracket
pugsy
Does someone know where to find the original bracket thats made to hold an umbrella for my tractor. It has the battery in a box under the seat. Also, where is that bracket supposed to attach to the seatbox /tractor? Maybe the original part # would help.
[b:654c4848f0][i:654c4848f0]original bracket thats made to hold an umbrella[/i:654c4848f0][/b:654c4848f0]
Take a look at the diagram below.
There is <a href=https://www.ebay.com/itm/325338320856?hash=item4bbfaccfd8:g:eek:2gAAOSwUyNjHHIs&amdata=enc%3AAQAHAAAAsLhVHn90cRcYKJ626yt1ozDV5A5XslF3bu66uCW%2Fv1wgtiinff0O5EIWK9u7lPlnOGEfNCYnCT6ayv%2FYh573S8NvtTj8%2BwxJO7ig0evTspt7FmGuxlfbYZAn9%2Br1mvqTRRHjgjTjvAaBIdNpvcOucj0HQ%2Bx%2FBFL%2BETw%2Bk4acNClT8st8VYllZeG%2BVqRRh6w6f4I1p0%2FQXiGCiBmIFnnFf4%2BN9CbuqIzbCFGsJryzeExj%7Ctkp%3ABk9SR9y4ufbsYA>one available</a> on eBay.
After inspecting all six photos, it appears to be a complete unit.
Hope this helps.
Do you want it just for a show tractor? For use they are no good as mounted too close to seat you keep hitting the bracket and anything fastenerd in it with your back on slightly rough ground. And getting hit a few times does not feel good. I junked mine years ago because of that problerm. Put an aftermarket bracket on steering shaft support with offset unbrella shaft. Worked good. 49 B & 51 A.
