Hello all. Long time reader here. Thanks for all the previous advice I've received. Sorry for the long post, just trying to get all the details in. I have a late 720 diesel with a serialized pony motor that is giving me fits. It was low on power, leaked everywhere, and fogged the county when it ran. I got new rods, mains, rings, honed the cylinders, cleaned up the valves and seats. I had the crank ground to .020 under. Rods and mains sized accordingly. The engine purred like a kitten for 3 runs of about 5 minutes each then came to a fast stop. The rear main bushing welded itself to the crank on the flywheel side of the oiling hole. The crank side of the bushing looked fine. I cleaned the motor of all the shiny bits, reground the main to .030 and a new bushing again. Motor ran again 3 times for maybe 8 minutes total and seized again. Bearing to crank clearance was .003" both times. Crank endplay was shimmed to spec. New thrust washers front and rear. 5w-20 oil used. oil pressure was 45 initial start, settled in at 40psi running. Oil passages are open and clean. Flywheel side rods and journal look good still. I assume they are getting oil so that means I am getting oil through the rear main. just the outboard side of the rear main is not happy. The little drain hole in the rear main housing is open. Gasket is in place correctly. I'm at a loss. Any ideas? I feel like I'm heading for insanity trying the same things over with the same results. Such a simple little engine is getting the best of me. Thanks for any guidance.
