This has been a real challenge as the bolts holding the intercooler corroded in the block and also in the intercooler as well, too much reaction
between the aluminum and the steel but i finally have it removed. Now the exhaust was even tougher cut the bolt heads off and eventually got the
manifolds off replacing both of them but will try welding nuts on the studs hopefully this will do the job as so far heating them has not got 4
of them out yet and it is only a 5,000 2owner tractor but never been apart since built 1977
