Monkeymaster
Good morning
JD 2840
Curious on other people's thoughts.
My 2840 needs it load shaft seals replaced, this spring after snow season, so I am always checking the oil level with the dip stick.
The manual says, pull stick, wipe off, reinsert until handle touches opening of tube, pull out to read level.
With that vague of an description, I think as long as the dip stick is wet, I am good to go.
Then the other thought, fill the darn thing up beyond the full mark, and be safe.
Can the hydrulic system have too much oil in it ?
I understand too low is very bad, but can too much be bad also?
Kinda like too much oil in the motor can cause the crank to splash and foam up the oil causing bubbles which in turn ruins bearings?
Any thoughts is appreciated
Thanks
JD 2840
Thanks
