706 Farmall
I am wondering what a 1936 John Deere B might be worth? It has flat spoke rims on the backs, tires are junk. rims on the front are just solid metal, tires are junk. The motor does turn over. It has not been run in many years. The exhaust pipe is missing back to the manifold, so I thinking weather has affected inside maybe. The gear shift is stuck (meaning you cannot move the gearshift), so the tractor does not roll as I am told. I am looking for an estimate of value before I go to look at it? The sheet metal is straight. The tractor is stored outside under a tarp. Thank You for your thoughts.
