tomstractorsandtoys
Today we tore down a 3020 syncro for a top shaft trans job. Every bit of the lining had peeled off the syncro plates. I have never seen that before. One or two small pieces that were still on just flaked off with my fingernail. Was it defective parts (tractor had been apart before), water in the hyd oil (a little bit was present) or did someone use a cheap oil? Current owner has only had it 3 or 4 years for light work. It is a 3020 side console without a rockshaft and has a wide swing drawbar. Has aftermarket fenders so most likely it had round ones originaly. Tom
