We have a late SN 91,xxx (hi pressure common rail fuel system) 7710 power quad that we are having trouble figuring out what the problem is. The complaint is that the hydraulic system is over heating on it and setting CCU015 code (hydraulic temp hi) and turning the hyd temp warning light on. It seems to be mostly RPM related, as we can get it to overheat with the tractor parked and the engine running at wide open throttle. We have tested the power quad air pump and it tests fine and the hydraulic system tests we have done all seem fine too. The main hyd pump stays on low pressure standby, unless a hyd function is activated, so that seems fine. Just running the tractor none of the hydraulic valves or components seem to build up any heat at all. The only thing that seems to build up any excess heat is the power quad unit itself. The power quad works fine and does not seem to drag in forward or reverse nor does it labor the engine in any of the speed ranges like it would if it had a warped clutch or brake element. We are about to the point of rolling the drive train out and taking a look at the power quad unit, but the owner wants to sell the tractor and doesnt want to spend a lot of money on it, but he will if he has to. I just hate exploratory surgery so I would like to be pretty confident that the problem is in the PQ unit before we go through the work.
We did find a DATC solution (#57370) that talks about a restricted return oil passage from transmission to differential housing, but I am not sure how this passage way could of suddenly got restricted after 20 years and almost 10,000 hours of operation. It would requires PTO housing removal to inspect for this and that is not a 5 minute job either.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
