I have a 4230 built mid 1975.Gonna replace
bearings etc..as there is quite a bit of up
and down play in axle but not leaking oil
yet.So in order to separate axle housing
from trans case looks like one brake line
needs to be removed and cab supported on
that side.My question is will axle housing
assembly clear trans case before the
outside of housing contacts bottom of cab
frame.Looks like it should slide out far
enough and then lower axle housing assembly
down to clear bottom of cab.Thanks,Paul
