burnsg2003
I have taken my 4010 to a shop to get the clutch rebuilt they have called me and told me the the synchronizer gear for 3rd gear and the
corresponding reverse gear is bad and that the third gear needs to be replaced. I was told it is on the bottom shaft which adds a lot of
hours to the job and that deere has made the parts obsolete. Does this sound reasonable. The third and corresponding reverse gear will shift
but have to kind of play with it to accomplish this I thought the gear shifting linkages might need adjusted. Any advice or information you
can give me would be appreciated. If the synchronize and the 3rd gear is bad where could I but them or if bad and can't fine parts what would
happen if i did not have the gears replaced could I just use all the other gears which do work. Thanks in advance for your help.
