Rod bolts - reuse?
Paul_IN
Can rod bolts in a 404 engine for a 4020 be reused with
success or do they need replaced? If its best practice to
replace do you guys prefer to buy Deere bolts, A&I, other
aftermarket?
The only thing I use them for is checking the bearing clearance during assembly (plasticgauge) then to the iron bucket they go.
Always replace them. Years ago dad overhauled a 4020 and back then we reused them. The farmer had a farm on both sides of a very big hill. He was going down the hill with a load of silage so the wagon was pushing the tractor some and one of the rod bolts broke. Our machine shop said there is more pressure on an engine in that situation than if he had been pulling that load up the hill.It even bent the crankshaft. Shop sent the crankshaft to a forge where they heated it and straitened it. That was 30 years ago and the tractor has been fine ever since. Tom
New bolts for sure. Torque is a measure of how far you stretch a bolt/stud. Precision engine builders for competition actually measure the stretch after torqueing to be sure it's right. A rod bolt that's been in an engine forever might not have the resilience to shrink and then re-stretch when re-torqued. Tractor engines are usually overbuilt a bit, but hey--why take that big of a chance to save just a few $$? Just my $.02 (adjusted for inflation--$05).
(quoted from post at 14:04:05 01/02/22) Can rod bolts in a 404 engine for a 4020 be reused with
aftermarket?
In original 1970 vintage manual, I cannot see anywhere mention of threw away bolt. Also the tightening torque callout is fairly low. Even at this lower eating, it is best to get new bolts. But qi donot think Deere is the only place to go. Federal mogul, Reliance, maxiforce... etc
I always use new bolts.
And new bolts are absolutely mandatory if you are using the revised torsue and turn method. I have never done it on older engines that did not have it in their manual. I am wrong?
change the bolts but-- you will need to recondition big end bore of the rod if you use new torque specs
the added torque will change the size and shape of the rod
For less that a 100$ bill I wouldnt dream of it ,
(quoted from post at 19:54:15 01/03/22) change the bolts but-- you will need to recondition big end bore of the rod if you use new torque specs
Could you please explain more?
