I'm looking to convert my 45 loader from trip action to hydraulic tilt and I will be needing to add additional hydraulic remotes to my 620 in order to do so. I would like to add a double spool open center valve to operate the loader but I am not sure how I should reroute the hydraulics. Simply put, can I just run lines from the factory scv to the loader valve and keep the hydraulic lever at the seat engaged to supply pressure or do I need to splice into the pressure line that runs from the pump to the factory hydraulic valve? Looking for some input from anyone who has done this. Thanks,
Pete
Pete
