Monkeymaster
Hello
2840
Pa bought this for his, now my 40 acres, using it for loader, blade, and snow blower work on our 3/8 mile lane, and occasional log, lift move off the lane.
This was bought with unknown hours, tach hr meter was replaced.
We have 265 hours in it since bought.
I plan on replacing the load shaft and all the bushings and seals this spring.
This tractor has given me no issues other than the load shaft leaking, but it has not had any service other than oil and oil filter changes in the last 15 years.
While I have the gallons of hydrulic fluid out for the load shaft, I plan on replacing the filters, clean the screen, ect, what else should be done with the rear end drained ?
When should the brakes be replaced, or what do you look for when it is time?
Is there a minimum thickness I could check ?
What else can/should be checked ?
Any other information or tips is appreciated
Danka
2840
Danka
