CX Gator Question (Help)
I can start my gator and drive it with no problems. Shut it off, and then come back to start it and it will not crank up, Let it set about 5-10 minutes and it will crank right up. It has done this several times. I am think it may be the Key switch or the that little gray box (computer) near the engine. Thank you.
A lot of variables here. How old is it? Is the gas fresh. When did you last change the fuel filter? When it doesn't start do you have spark at the plug? Have you replaced the plug? Have you tested the coil? If you're certain it's getting fuel then go into the diagnostic/troubleshooting flow chart in the service manual which will require some tests with a multimeter to determine if there's an electrical problem.
Has fresh fuel and a new fuel filter and spark plug. Gator is about 15 yrs old, (no Manuel) I have had it for about 10 years and use it almost daily and it is always garaged. Been very reliable. I am going to get me a spark plug checker and see if it is firing when it decides to throw a fit,
