1945 model A
Need help.My tractor is hand start. Been sitting 3 months inside. Went to start today and with 3/4 choke it is only firing on one cylinder. Never did this before. Autolite plugs which seem to be okay. Pulled valve cover to make sure there were no stuck valves. Not sure which cylinder is not firing. How do you determine this? Will someone help me, please? Thanks!
[email protected]
Pull a plug wire out of the mag while it is running. If it dies the live cylinder is the one you pulled the plug wire for. If it keeps running the dead cylinder is the other one.
