4020 syncro clutch problems
Kelly vestal
New User
I recently saved a 4020 from the scrap yard, long story short, the clutch pedal sticks so I split the tractor. There was a ton of water in the housing when i removed the view plate under the bell housing. So, everything was rusted. Im trying to remove the pto clutch forks so I can get back to the actual clutch shaft but my tech manual doesnt say how to remove the pin that runs along the bottom of it. I removed the covers on each side but I am not sure how to get the pin out.... help.
KV
Thanks Sam, I hit on it until I was afraid I was going to break something. Its seized pretty bad with rust and ive been soaking it for several days. Im at the point of putting heat on it but not sure if that would cause a future failure.
