Just bought a '76 450C with a wrecked 4219T motor (rod thru block) and a spare 4239D to replace it.
Appears a turbo has been added to the 4239D. The injector pump is a DB2-4451 of which research reveals is from a 410 tractor. (probably where the 4239D came from!?). The injectors are matched for a 4239D (22203).
Running on the test stand was a tad rough and revs at high idle hunted, so I bought 4239T injectors (22265) for it and it now runs very cleanly on the test stand with no smoke (no load tho).
I just read however that the 4239D block (or the balance shafts) do not have the drillings for piston oil cooling and I may have problems with overheat under heavy load with the turbo.
Can anyone weigh-in on the ins and outs of the D and T variants and whether what I've got is a 'go'?
also ....
I'm not sure whether fuel delivery is sufficient with the DB2-4451? (or if the Transfer Pump pressure can be set a tad higher to increase fuel?) OR does that only affect timing advance etc.
I also have the old pump off the damaged 4219T (JDB2802 - a 'Rebuild' unit by Deere) but the weight cage has been changed (maybe in subsequent rebuild?) for the newer EID type and I'm not sure the timing mark has been scribed in the correct position!
I know a rough guide to the position can be determined by looking down the #1 injector output hole (with the banjo and line removed) to see the pressure port hole when it appears with rotation, but the side plate states the original cage marks were 'Timed End Inj'. and that little hole is visible for quite some crankshaft degrees. Is 'End Inj' when the hole 'sunsets' (disappears)?
Finally,
I've worked on a Case 188D and recall timing it to 8 BTDC by setting the Flywheel to 8 degrees and lining up the marks on the injector pump. (the pump timing marks are the actual injection rotational position)
But on the Deere, the procedure is to lock the flywheel with the timing cover bolt pin at TDC (?) then the pump adjusted to align the timing marks. I therefore presume the pump for the Deere has timing marks which when aligned are not the actual injection point but actual injection occurs maybe 8(ish) degrees before these marks in actual operation???
Anyone confirm this please?
I read a new weight cage comes with no timing marks and must be added by the re-builder. So, a new owner of the pump has to rely that the timing mark was scribed in the correct position.
But if the rebuild was a DIY job, and the DIY re-builder somehow just noted the pump position upon removal then fitted in same noted position after re-build, then how the heck does a new owner of the pump find out where 'Times End Inj' point is ???
At least with the DB pumps the injection port timing can be viewed down the banjo bolt hole but on the DB2 pumps, the banjo holes are out the back so the internal rotor holes cannot be seen!
also ....
Finally,
