JD 720 Gas fuel shut off AR973R
Hello folks,
Wondering if anyone has had experience in compensating for a missing fuel shut off valve PN AR973R. Ive seen some post from 9 years ago here on this site at this link: https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=jd&th=428805
I dont know if others have just tried a normal shut off valve from tractor supply. I do not know the thread size for the bottom of the tank yet, Im in the planning phases of what I need to buy with this new to me tractor. The fuel shut off appears to be missing the needle valve. See pictures. It would be parts diagram number 8C. Im new to the 720 and I find it interesting that they added a fuel shut off valve at the bottom of the fuel tank as well as the auto fuel shut off sediment bowl. This was an improvement by the Deere engineers at this time for sure so the farmer could shut off the tank without worrying if the diaphragm was worn out and cause fuel to enter your crankcase like it has done to me on my 60. Regarding the 60 I have found that even with using non-ethanol gasoline, the auto fuel shut off diaphragm should be rebuilt once every 5 years to prevent the leakage problem. I used all new parts and only have been getting 5 years out of the diaphragms sadly. Any others have thoughts on the 720?
Fred,
This is what my 70 gas std had on when I acquired it. I removed it and replaced with a regular sediment bowl, can't remember if it was actually leaking or why I took it off. This tractor has no dip stick to check the oil so harder to detect the leak until you have a crankcase full gas. Got a stock fuel line from Sharps.
Thanks folks on a 720 gasser it has a fuel shut off valve under the tank then a long line that goes to the sediment bowl with the auto fuel shut off. I have the means to rebuild the auto fuel shut off sediment bowl. I was looking for a solution for the valve under the tank that appears to be missing on mine. Here is a picture of the sediment bowl which is down stream from the tank and the missing shut off valve.
This is what I use on my pony motors, readily available. If there is an OEM valve NLA from Deere maybe JoeTractor (Greg Stephen) could help.
Hey those look nice! Thanks for posting. You wouldn't happen to know the tread size on those two models would you. They look like they would work.
